Q45tech wrote:There is an ideal relationship between pedal ratio, mastercylinder piston size, and caliper pistons diameter.
You always trust the factory to match these components.
Most Nissan mastercylinder bolt to the vacuum booster....universal fit here at least in older cars.......whether you have to change the hard lines is another matter.
So its gonna be trial and error pretty much, unless I find someone who has tried this already, maybe I should also see if I can fit the vacum booster from a z32 on there also.
Thanks for the great info, I have been researching this a lil' for a while.
Rubin
