Axles
Jdbiss
Car: 1993 Nissan 180sx
Hello folks, quick question about axles. I've searched, but I'm having a hard time finding the answer. I have a 93 s13 180sx, sr20det. Im looking to swap out the axles, as either my axle or subframe is bent. However finding a stock JDM axle is proving to be pretty hard, and wildly expensive for aftermarket.
Are the 240sx axles interchangeable? If not, what other stock axles if any fit?
Thanks in advance!
NukeKS14
Car: '95 Nissan 240SX SE KA24DE-T
AC Cobra Mk IV Rep.
2020 Honda Civic Si
Yes, 240 axles are the same (exactly same R200/R200v differential, subframe,etc...)
Just make sure you verify your bolt pattern on the output shaft. Should be 3x2 if I'm not mistaken.
like so
Jdbiss
NukeKS14 wrote:
Tue Apr 07, 2020 7:00 pm
like so
Awesome, that makes this a much smaller issue. Thanks for the reply!
NukeKS14
AC Cobra Mk IV Rep.
2020 Honda Civic Si
No problem. Best of luck. Rock auto usually has good deals and accurate pictures of what youre getting.
