axles
Blast down the 1320? Love the 1/8 mile action? Here's your forum.
wannaS13
Car: 92 240sx
axles keep breaking on me first it was the transmission so i got the z32 mazworx kit now yesterdayi broke my 3rd axle. just wondering what you guys are running. i have an act 6 puck unsprung that i try like hell to slip but just seems to grab. any input would be great
MeanGreenS13
Car: 2011 Chevrolet Silverado 2500HD
driveshaft shop axles FTW!
wannaS13
Car: 92 240sx
yea kinda figured that was what my answer was, there is a local guy here that make custom setups so i will check him first. which ones it looks like the 500hp ones only replace the bars
MeanGreenS13
i didnt f*** around with my car, i have about 1400 dumped into the rear end cause i was going to go dragracing with it. now its just a street/slide car
rb25drag
Car: 1990 Nissan 240SX 5.3 Chevy + 60mm turbo + blow threw carb.
I have heard of people breaking the driveshaft shop axles also.
Also I wouldnt give 1400$ for a set of axles from them either
I personally am setting up to do a 8.8 ford rear end swap. There is no Nissan differential or axle that will hold up to Hard launches with slicks on a Good preped track.
With my new 2step system I will be leaving the line @20psi of boost SO I need something thats going to hold up.
Plus there cheap to build and install.
wannaS13
Car: 92 240sx
will that be a 4 link setup? or do you have something else in mind
MeanGreenS13
i said rear end not axles lol i got 700 in axles and the rest is in the rear end itself
rb25drag
im not doing a 4link setup.
I plan on Making brackets to accept my Stock Strut/spring setup and Brackets to keep my current calipers and Rotors. Other than that its a simple setup.
a mini spool for the 8.8 is like 120$ and gears are a dime a dozen. I really think my car wants a higher gear than the stock 4.08 I believe It would pull harder down low if I get like a 3.55
MeanGreenS13 wrote:i said rear end not axles lol i got 700 in axles and the rest is in the rear end itself
I personally have not had a Problem with a Stock Welded differential. Its just the axles will not hold up. But also by the time you change all the bushings ETC. Its gets $$$$
wannaS13
Car: 92 240sx
i just want to cut sub 2.0 60's at this point. i know that it is probably my driving style but i just cant slip this clutch. i am going with a q45 setup for now as igot everything for around 125 from a pick n pull. i hope with the 4.64 gears it will go into the 11's. then i can start messing with the spray
rb25drag
Not sure what motor setup you have or what clutch setup you have. But I have went 1.6 60's on the stock r200 rear end and stock axles and Mt et streets. I also have a 1500$ cusco exedy stg 4 clutch. It is the stiffest clutch I have ever worked with.also you gotta figure out where your motor likes to launch best at. With my rb25 it likes to leave the line at 5500rpm. On my new motor and rear end setup. I wanna see 1.3-1.4 60's
nelson8708
Car: 1989 Nissan 240sx Fastback
1994 Acura Integra LS
The q45 diff setup is a strong one for anyone who is looking for something strong and cheap. The lower ratio is a plus also....
wannaS13
Car: 92 240sx
im not making more than 320 unless i spray it so i dont need the ratio. i have 4.64's which i love, now its just a matter of finding a drivers side z axle hahah i dont think they exist
Return to “Nissan Drag Racing Forum”
