08RogueAWD wrote: ↑Sun Dec 08, 2019 7:56 am
The axle seal is real easy. Just gotta get the CV axle out of the way. I don't see why they want $500! Depending on your local labor rate, it should be maybe $200 on the high end to change at an independent mechanic. I would change it sooner rather than later too. If the leak suddenly gets worse, you may not know it until it's too late.
Because it’s the dealership where they squeeze every LAST penny from you.
Just spent over $1,000 just replacing both control arms.
Altogether, over $1,300 to bleed brake lines and an alignment.
Yes, I am a dumb s*** for doing that. They got me right in the nuts.
