DragonMaxima »
https://forums.nicoclub.com/dragonmaxima-u40385.html
Sat Sep 15, 2007 2:34 pm
Ive done an axle replacement on a 3rd gen and its messy as hell.
You have to:
Jack up car and put on blocks
Remove wheels
Remove front rotors (Makes it easier later)
Tie caliper up out of way (also making it easier later)
Remove axle hub nut
Slide outter axle spline out of hub
Remove shorter half axle
Heres the fun part
The longer half axle will have a set a bolts that mounts axle to chassisthose bolts have to be removed before other half axle will slide out.
With a lil bit of muscle the axles will slide out.
oh, before i forget, be sure to remove a good portion of the transmissonfluid, or it will pour out all over the place.
Once you get all that done just do the reverse for installation.
it can be done in a day with the right tools and a buddy to help.
It seems like a much harder task than it actually is.
I was thinking it was gonna be this uber-difficult task and it wasnt.
Thats the basic premise for it, the haynes manual was a good guide line.
You might wanna try and get your hands on a a Nissan factory Service Manual also, best money i ever spent.
Good luck.
