axle bolts
A forum for lovers of Infiniti's hot-rod crossover, the FX! In 2014, all FX models will be named Infiniti QX70, in line with Infiniti's new naming structure.
crankor
Car: 2011 Infiniti FX35
My axle literally fell off the other day and there were only 3 bolts to be found resting under the base and one was snapped (thankfully none are broken inside where it mounts to) the issue.... I thought i had found some online from autozone and received them today and they are ofcourse completely wrong. So I went to the hardware and got some flange bolts that match all except that the head on these ones are a 13mm vs what I assume to be a 10 on the other ones... they do look like there is tech enough clearance on the axle itself but I think it's making me struggle getting any combination of ratchet to fit on there. Is there any place to get the proper bolts or do I just make work with what I have?
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Exactly which bolts are you talking about? If you mean the ones which hold the hub to the knuckle, they're part number 081B4-2605M and it's a good p/n for both Infiniti and Nissan. You can get them from InfinitiPartsDeal.com if you don't want to pay list-plus at the dealer.
crankor
The ones that hold the inner drives shaft to the other half of the axle... not sure about proper names. There's 6 of them. That hold this thing
VStar650CL
Technical Expert
Parts book says those are p/n 39606-JF00A for the rear shaft, 08310-30612 for the front (that's a front, I think?). I imagine allen or torx cap screws would work fine too.
If you can get me a pic and thread pitch of the remaining one, I may have some in my stash.
crankor
AZhitman wrote:
Fri Jun 27, 2025 8:19 pm
I think I found the right ones this time..I think
crankor
After waiting almost a week, I got an email saying the supplier is ordered from can't fulfill the order 🤦 making me wonder if any of these googles sources have any
VStar650CL
Technical Expert
I don't see any of the Nissan part available anyplace, Melloy Nissan has a couple but they don't have 6. Even Amayama shows no stock on all 3 variants.
That said, I'd be very certain you can use allen or torx cap screws if you just get the pitch, diameter, and length of the survivor and look up something that fits in McMaster-Carr.
crankor
K wasn't sure if those would be more prone to snapping. I may try another attempt at the bolt variants I got that have the 14mm head. It looked like two would fit without overlapping but I probably can't fit a wrench over both. Maybe I could use 1 bolt and 1 torx for each side
Why not just use the correct fasteners?
14mm head is too big for those, and when you mix/match things, you have different (albeit minor) weight and clamping force of each side.
It fell off for a reason - either improper installation or improper hardware.
VStar650CL
Technical Expert
The thing I always liked best about McMaster-Carr is that you can get exact dimensions for practically every fastener they sell, and for most you can get strength and materials specs as well. So there's no reason to get anything that won't fit in the hole or won't be strong enough.
Yep. My suspicion is they're shanked G8 bolts with a 10 or 12mm head.
crankor
So now several weeks later I once again got shipped the incorrect bolts. So id say it's safe to assume nobody actually has them. Im hesitant to use the torx screw but sounds like that may be my only option to
. The 14mm bolts i have are just barely shorter but I dont think I could fit a wrench on them. Socket wont work
I don't want to be a jerk here, but buying a thread checker would've saved you a ton of time. I think I even offered to supply them with the correct dimensions.
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
crankor
AZhitman wrote:
Mon Jul 07, 2025 8:32 pm
I haven't had any free time for the car for a while. Ill try getting the dimensions.
crankor
I'm still gonna try getting the specs but I did finally find a 1/4 swivel and I think I can make the bolts I picked up work. Turns out they are actually a 13 mm head and not a 14. I do have 2 of the "original" bolts (one it a bolt with an Allen as the other is just the bolt head) so I was gonna see if I could use one original with one new one space wise.
VStar650CL
Technical Expert
If you're using a mixed lot, make sure they weigh about the same or you'll throw the axle out of balance. Even a big discrepancy won't create much force because they're close to the center of rotation, but the bearings will know it's there and it could cause an annoying vibration on the highway.
^ This.
crankor
So when i was trying to put in the last bolt, it wouldn't go in and it was getting late so I just left it out. I came back to it today and found out one of the old bolts is still in there. Doesnt seem like theres going to be any way to really get it out since I doubt I can fit a drill in there to use an extractor. Maybe if I took the axle out but I dont really want to do that right now. Unless they make a manual turn extractor.... which now I think of it I believe they do..... hmm.
Return to “Infiniti FX35 / FX45 / FX37 / FX50 / QX70 Forum”
