Axle bolts needed...
marioc89
Car: 1990 Acura Legend coupe
2000 Infiniti Qx4 3.3L
Anyone know where I could get the bolts for my cv joints? The bolts that screw into the crankcase.
atraudes
Car: 2001.5 Infiniti QX4 4WD
These guys, right?
You can get them at a dealership or online. If you're in a pinch and pressed for time, you could probably find something compatible at a hardware store. According to the parts diagram at courtesyparts, the bolts are part number 39100A and the washers are 089151381A.
Make sure to use threadlocker blue when you reinstall them. A trick I learned to get them torqued down properly without the wheel spinning on you is to stick a screwdriver in the vanes of the brake rotor so it butts up against the brake rotor while you're tightening them.
marioc89
Yes! Precisely! Thanks a million.
atraudes
You got it! :dblthumb:
