axle bar upgrades (broken axle club)
tcgreaux
Car: 1996 nissan 240sx with vq35de rev up, 2007 tacoma x-runner
im looking for axle bar upgrades, im aware that driveshaft shop sell them but im looking for just the bars, i feel there way over priced for a peice of splined steel.
kenno470
Car: 1995Ish Nissan 240SX (P-I: Retired 2012)
1997 Nissan 240SX (P-II: Began 2012)
Mazworx makes a set. How are you breaking them? We have over 500hp at the wheels and don't break them. Are you drag racing and side stepping the clutch?
PEZi
kenno470 wrote:We have over 500hp at the wheels and don't break them.
you also drive like a grandma :tongue
tcgreaux
first time i had the car at the track it a vq35 rev up motor on stock 350z rear tires 245s. slightly used brigstones. droped pressure to 12psi bout a 8 -10 sec burn out, hooked hard on the launch then "snap". the rear end has been up graded to 93 j30 lsd with the axle shafts. both outer and inner joint are ball and cage joints. the axle shaft snaped about a 1-2" in from the outer joint driver side. probble didnt help that i ran about 10 times in a hour :) that vq is deffinetly puting down some torque.
