Axel Half Shafts as a source of Vibration?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
I am sitll kinda chasing this vibration ive been having... Shimming the center bearing kinda helped, however above 80MPH when i let off the gas it vibrates more and then when i press the gas down it goes away for the most part...
Someone said they replaced their axle shafts as a way to rid a vibraiton.. has anyone ever heard of this happening? I have a spare set of axles and we can see what happens, but before i waste any time id like to see if anyone has any experience...
Q45tech
Have you changed all the differential mount bushings? And rear wheel bearings?
We have never changed a half shaft unless visaby damaged fron hitting something.
elwesso
2007 BMW M Coupe
I have replaced the rear wheel bearing on the passenger side... diff bushings have probably 25k on them (since they were done at T3 with the engine swap). I just had the diff bushings out and they looked pretty good, still pretty pliabile and didnt crack or anything.
