underground57 »
https://forums.nicoclub.com/underground57-u18524.html
Sat Jan 21, 2006 3:13 pm
You can get a helicoil kit online for like $25 iirc. Then all you need is the correct drill bit, a drill, and a steady hand. The kit should come with directions, but...
[edit: I forgot to mention when the bolt is stuck and won't come out, which is what happened to a friend of mine's car. With a smaller drill bit, we drilled a hole down the middle of the bolt. Then we used a reverse drill bit, which you should be able to get at any hardware store, and used it to back out the bolt. I'm not sure of the exact name of the bit, but if you explain the situation to the hardware store person, they can find it for you.]
- Mask the area you are working on so no metal shavings get into your engine.- Drill out the stripped hole.- Put the coil on the helicoil tool. align it straight over the hole and screw it in.- When you've got it all the way in, depending on the tool, you either twist it until it the part of the coil that holds it to the tool snaps, or you "unscrew it" and it snaps.- Repeat for as many holes necessary.- Check to make sure you've gotten all the little metal shavings out, then bolt that sucker back on. - TADA! All better. Should only take you an hour or so (and thats over estimating).
[Side note: since the head is aluminum, magnets don't work to pull out the shavings, you can try a vaccuum with a small attachment, or what I did because I didn't have a vaccuum around, which was roll up pieces of duct tape and 'stuck' all the little pieces out.]
If I missed something, post it, and I can add or edit. Good Luck.
Modified by underground57 at 8:28 PM 1/21/2006
