can I check the ecu even though it doesnt start? I checked the spark plugs and the gap. Coil packs are good. How can I check my ignitor?pulsar gtr wrote:It sounds as if you have a bad ignitor, usually these are the symptoms, but also, make sure when the car won't start that you have spark on all plugs.If so, then check for fuel.Run diagnostics on the ecu and see what codes you get.
RafiPULSAR GTR
