eazye2000 »
https://forums.nicoclub.com/eazye2000-u30064.html
Tue Oct 30, 2007 2:46 pm
Man, my SOHC KA did that same crap man. I never figured it out totally. I took the car to a shop(back before I knew how to work on cars) and they said it was 2 teeth off with timing. So they fixed it, and it brought the RPM's up a bit higher, but still bogged up high. But STILL taking about 10% of the throttle away, made it rev up the rest of the way.I had the ECU reset, the timing chain corrected, and timing set to I think 15 BTDC.. Even put in a Blaster MSD coil an a 6AL box. Didn't fix it.
This was totally irrelevant, and a waste of your time guys. I apologize..
