Kansei240sx wrote: What kind of honda did you have before this post?
loser
dont be jealous, because you aren't creative enough to come up with or try this.
FAST-DATSUN wrote:Planning, Planning and Auto-cad ... you need to replace the front frame to get clearance for axlex and proper aligment of the engine, axles and suppension.. and Must use the Skyline suppension Mated to your new custom front end... Oh modify the floor pan and pass seat for clearance
ok... no... really there are many ways this could be done. the simplest would be to get a gtr half cut and work a piece at a time and actually see what you have to move. grafting the right side of the firewall and floor out of the skyline would actually be easy. not a big job at all for an experienced bodyman. we replace rails all of the time and sectioning a firewall would not be that big of a deal. go talk to an importer and tell him what you want. i guarantee he will be able to make a call and get you all of what you need. a slightly more difficult but totally feasable way is... have you ever seen a pro rwd celica or solara? those cars are all tube up front and rear. all you would need is to do the all tube up front... so it would be easier than what those guys do.
27RB240 wrote:Or be like everone else and get a Evo or a wrx...
those cars are not even comparable to a stock skyline much less a light weight smaller skyline powered 4wd 240. those cars are awd the skyline is a 4wd. the way ATESSA works is the rear wheels are always under power, because the car is rwd. the front wheels only go under power if the rr wheels spin. think about it, there is no better way of getting the power to the ground other than that. evo's and wrx's have center diffs, so when you are accelerating hard the power all goes to the easiest wheel to turn which is normally one of the front which normally ends up in tire spin and lost time accelerating. ATESSA OWNS AWD.
xekushnr wrote: ALTESSA
and... theres no L in ATESSA
but dude, seriously, if you are gonna do this you had better get on it because you arent the only one in the nova ish area thats gonna do this, and we are gonna get started on ours soon as well.
Modified by rbosacco at 8:31 PM 6/13/2006
