nametakennow »
https://forums.nicoclub.com/nametakennow-u713.html
Sun Mar 19, 2006 8:44 am
This is an idea I've thrown around for quite awhile. Unfortunately, I've never had the money or time or anything to do it, but down the road I may.
Yes, it can be done.
Think about it, the "hump in the floor" exists in Sentras, so the ability to put a driveshaft also exists. Though some say the tunnel does not exists... which also makes sense... so maybe it's a bit more difficult than simply swapping, and the suspension components would be an issue, so it would require swapping in essentially a complete Pulsar rear end.
Still, if you've got a B13 SE-R around, it'd be a fun project.
edit: Did some searching. Apparently Japan had an AWD B13. Import it . It's not like anyone would be able to tell, except it'd be RHD, so I guess you could swap over the parts.
AWD B13 \/
