Hi Clifton,I have an AWD Cima front cut. We are playing with one now.Basically what you said first is true. The front diff is attached to the sump and the shaft runs through the sump. Just like an RB26 set up or a (AWD RB25). How ever everything is bigger, unlike the RBs diff being a cast part of the sump the VH uses a steel casing bolted to the block and sump. The diff itself is also larger in diameter.If I can be of any further help just let me know.Clifton wrote:Does anyone know anything about the VH in the FGNY32/FGNY33 Cima's. This was the awd Y33 version. I have found links in Russian and Jpn but nothing with even a pic of the drivetrain. Was wondering if the front diff was attached to the oil pan as the RB26 or separate like a D21, ect.
Hi David,I have pictures,Send me a email address and I'll shoot them through to you.David Steele wrote:Can you take a picture of this? I'd like to see it.
Cheers
These are extremely hard to acquire, probably no lsd in it .XRATED wrote:So to confirm, this vh41 is from a y33?
Also, I'd love to see what port style this motor has.
Anyone know what ratio this diff is?
Hi there,They came out in the Y32 and Y33 Cimas in Japan.Basically just look for an "N" in the Chassis codes eg Y33 is GF-FGNY33 and the Y32 is E-FGNY32.The diffs are a 3.692.The front Diff is an open style.Rear is a VLSD.XRATED wrote:So to confirm, this vh41 is from a y33?
He's doing one in Stagea and it will stay 4wd.Clifton wrote:gianavel, thanks alot for sharing your pics. I looked for hours. Doesn't look like it will work in an S30 though. Diff is a little too far back without moving the engine 10" forward and having a horrible weight distribution.
What are your putting yours in? Keeping it awd I assume?
Hi Clifton,AWD S30?Do you really need it? The chassis in those babies are pretty good aren't they?I have no hands on with them, but from what I have been told.I don't know, I think sometimes the whole AWD thing is over played, for a performance car that is.I prefer Chassis balance to AWD any day, again performnace based vehicle.Would be pretty cool though!Clifton wrote:gianavel, thanks alot for sharing your pics. I looked for hours. Doesn't look like it will work in an S30 though. Diff is a little too far back without moving the engine 10" forward and having a horrible weight distribution.
