Smurf6x6 »
https://forums.nicoclub.com/smurf6x6-u5616.html
Mon Mar 27, 2006 5:27 pm
Over the winter I rebuilt a awd ca with the intentions of converting it to RWD and intalling it in my coupe. I'm noticing a couple problems now with the intake mainfold. The placement on the RWD ca manifold has the brake booster vacuum on it while the AWD doesn't. I beleave it's right under the manifold, but i'm not to sure the Line sort of t's off. The Vac line setup is different than my RWD manifold also. But I need to know what really needs vac and what I can cap. FPR, Swril controls, Idle air, vac for the booster, wastegate. What else do I need to get her to run right. I'm hooking most up before I put her in the bay this weekend. I do not want to use my RWD manifold cause the AWD is already ported.
Thanks for the helpNate
