Away to make horsepower on my 93' Q45
hillq45
Just wondering if anyone know's of anyway to make more power with out breaking my wallet? Also is removing the rear muffler going to reduce or increase the power?
krazy4
Car: want a Q45
it probably wont add or take away any power, but it will soung goooooooood!
hillq45
Yea,I just cut it off about 5mins.ago and it sound's pretty good.I just bought the car last week and im trying to up the level of performance alittle,any ideas?
lino
Car: 1991 Q45a Fed-Spec, IQP/White, Texasoil 9 Accumulator Recharge, '93 TCU 1st Gear Start, JWFSB, B&M 70268 Transmission Cooler, BBS Forged Wheels, DRLs, Silverstars, Tint, Very Well Serviced.
Welcome to Nico
For extra power do a search for - NICO ECU It's the best bang for the buck.
Rear muffler - as far as I know, there is no power to be gained by removing it.
hillq45
Thank's for the info,I also like the white int. my whole Q is black.
superuber
A diff gear change will do wonders. The 4:08 will not give you more hp but you will get better launch. And yes, nico ecu's are really nice.
lino
hillq45 wrote:Thank's for the info,I also like the white int. my whole Q is black.
Black on black is pretty rare. I've only seen one '93 black/black.
lino
superuber wrote:A diff gear change will do wonders. The 4:08 will not give you more hp but you will get better launch. And yes, nico ecu's are really nice.
Isn't the 4.11:1 the good one?
superuber
yes, the GTR rear diff is the way to go. But my 408 is pretty close ratio wise.and somewhat cheaper if you know what your doing. Lots of threads on this issue.
hillq45
I know the car is rear but your's wheel's look to be fwd offset.
Modified by hillq45 at 7:58 PM 4/12/2007
Modified by hillq45 at 10:45 PM 4/12/2007
Q451990
I know this isn't really an answer to your question, but getting the car back to OEM performance specs. will go a long way. New owners frequently find maintenence issues that rob loads of horsepower (bad knock sensors, dirty intakes, incorrect non-oem spark plugs, dirty injectors, bad thermostats, etc.) A Q performing at OEM New specs. will be pretty impressive! Then adding some suspension upgrades and the "NICO ECU" are nice gravy items.
You might also read up on the whole timing chain guide issue before you put a whole lot of $$ into it. Some '93s have the updated guides, and some don't. We haven't really been able to figure out a true cut-off date by VIN yet.
Welcome to the club!
Heath
hillq45
Thank's for all your helpful info,I've been working on car's for about 9yrs.and building alot of muscle car's like older Chevy's so the hole import thing is alittle new to me.
redtop91
Car: ↑ ↑ ↓ ↓ ← → ← → B A Start
Cheap, Powerful, reliable. Pick two.
hillq45
redtop91
What?
Push the throttle pedal all the way down.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Q451990 wrote:I know this isn't really an answer to your question, but getting the car back to OEM performance specs. will go a long way. New owners frequently find maintenence issues that rob loads of horsepower (bad knock sensors, dirty intakes, incorrect non-oem spark plugs, dirty injectors, bad thermostats, etc.) A Q performing at OEM New specs. will be pretty impressive! Then adding some suspension upgrades and the "NICO ECU" are nice gravy items.
Heath
I totally agree. A properly sorted Q is not short on power... unless your used to driving mid 12 second or 13 second cars, the Q is not a slug by any means!
ScottJackson
Car: 91 Q45, 92 Q45a, 93 Q45, 79 BMW 635CSi, 95 BMW 540i
Hehe, that was my problem... I was getting bored with my '89 camaro (400+hp) when I got my Q... and then the BMW 540i. Neither are anywhere near thrilling. It's just too bad the camaro was such a tin can. Looking back on it, I probably woulda been better off spending a little $$$ on weatherstrip, sound insulation, interior (including new seats), and converting it to 13" C5 'vette brakes than to buy the Q45s and BMW. Oh well, at least I haven't had but 1 speeding ticket since I sold the camaro a couple years ago.
