I want to believe you, but how did you calculate the mpg? 65-70 with three people is so far off my best using cruise at 65 by myself (30 mpg). Fill the tank to the first auto shut-off then divide by the miles driven since the last full tank where you went with the auto shut-off?roboturner wrote:I took a 5 hour round trip to help a friend scout out a new apartment.
Went 65-70 pretty much the whole way. This was with the air conditioning on full blast (temperature highs here in Louisiana have been around 105 the last week or so) and myself, my girlfriend, and my buddy in the car.
I understand your skepticism, and while I can't vouch for the accuracy of his calculation, his Versa's transmission could is a crucial detail.fjwagner wrote:I want to believe you, but how did you calculate the mpg? 65-70 with three people is so far off my best using cruise at 65 by myself (30 mpg). Fill the tank to the first auto shut-off then divide by the miles driven since the last full tank where you went with the auto shut-off?
That's why I never look at single tank values, but averages over several, as my sig shows.srellim234 wrote:I often find a discrepancy from tank to tank
Before I left, I filled up and reset the trip. When I got home, I filled up (stopped at the first click-off, as I always do) and divided the gallons I pumped (5.41 into mileage from the trip (227.4) and came out with 42.0332.fjwagner wrote:
You're never going to use every last drop of gasoline...so no, you shouldn't divide by the tank size, just divide by the volume you pumped.Codelicious wrote:How many gallons of gas does the Versa tank hold?10?12?
Couldn't you just take the miles driven and divide it by the size of the tank? (that is.. if you filled it all the way up!)
Or the overzealous fill. Case in point: my best tank in my last trip was 47.61 mpUSg [57 IMPmpg, 4.94 l/100 km] . . . to which I say "no way".srellim234 wrote:I'm not sceptical of the calculation but I am sceptical of the completeness of the fill-up.
My best ever tank was 36.4 mpg but I'm sure I was in the 40+ club for a while on that tank.
it holds 14GLCodelicious wrote:How many gallons of gas does the Versa tank hold?10?12?
