average gas milage? and power?
newboyspo
Car: 1990 240sx RED!!! Coupe
HI, Sorry for the log post...
I have had and still am having many problems with my 1990 240sx ka24e.
When I bought it it ran like a dog, (rough idle, missing at idle, hesitation about 8 mpg) so I replaced/tested everything I could get my hands on including changing out all of the vacume hoses (I bought a spool and went to town).
I finaly gave up and took it in to a shop, they hooked it up and it was running at 11% at idle (I do not know what this means) and should be around 1% so they did a smoke test on the vacume (no leaks) and cleaned the injectors, did a wet test and found 150 psi, and then it tested at .95% at idle. But after I took it home I found the vacume line to the charcoal canister unplugged......
I plugged it in and now it does seem to run a little better and I am getting about 17mpg but my idle is still rough, (shakes inside the car) and randomly pops like a fop......fop.fop.......fop sound at idle, and smells rich at the back, it doesn't seem to have as much power as I was expecting?? My son has a 91 with a ka24de and it will run circles around mine... and I know it has about 10 to 15 more hp but I have removed the whole AC and clutch fan to try to make up the diff, but it is still sluggish
it still acts like it has a vacume leak somewhere.It has a new cat and exaust 2.5" new temp censor new egr valve, new plugs, wires, cap, rotor .The ecu reads 55
Help?please?newboyspo
newboyspo
Help?
benzydad
Car: 94 Pontiac Transam, 92 Nissan 240sx
Why don't you change your canister? I had similar problem long time ago. Even though it was different car, it worked for me. Hope this would help you out.
benzydad
And the milage on my car (92 240sx, manual trans) is 22mpg most of the time. (city & highway mixed driving condition)
180fan
Car: 89 fastback
Have you tried checking your injectors?
