Thank youl0nestar wrote:Greetings Hazazi.
the boost to 19 PSIDarius wrote:How much boost are you running? For an upgraded turbo, injectors, intercooler, tb and intake manifold, that power level is not very impressive. A stock RB25 can push ~305-320hp at 12 psi of boost.
The CAS looks like it is clocked to one side of the slot. Have you checked the base timing to verify that it is 15 degrees when the engine is at operating temp?
What fuel rail is that? The 7MG?
no RB26 injectors 444ccinjectors An engine 7mgeh? wrote:19psi is too much with just an S-afc.Lower boost or you may break the motor. The RB26 injectors are too small for 19psi and that size turbo.
Does the rear suspension system in sky line gtr same 300zx tt ??SullivanRacing06 wrote:turbo is also a ebay special, no garret, mabey a garret style
