bentvalves »
https://forums.nicoclub.com/bentvalves-u46428.html
Sat May 12, 2007 4:46 am
Going to try and establish oil pressure today, maybe even start the *****, but this AVCR has me hung up.
Im settin it up for my car, and there is a throttle sensor type setting, here are my options x 3.
when throttle is CLOSED 0v-1vwhen throttle is OPEN 3v-5v
when throttle is CLOSED 3v-5vwhen throttle is OPEN 0v-1-v
**there is no throttle signal
Also, im going to look in the FSM, but is setting the TPS a two man job?
Greg
also, when I first put power to my ECU the other night and began to setup the AVCR.....It got late I was tired and decided to call it a night. I was in the middle of setup and turned the key off, but the AVCR remained powered up. I had to pull the battery ground to kill it and Im curious If I wired it wrong. I double and triple checked, but It IS wired correctly.
Modified by ks13 at 8:04 AM 5/12/2007
Modified by ks13 at 10:06 AM 5/12/2007
