AVC-R Set up
Drift_S13s
Car: 1990 240sx
I have a sr20det redtop with a t3t4 garret turbo, and a 44mm tial wastegate, im using an avc-r for my boost controller and im not able to change my boost i think my vacuum lines arent ran correctly because every time i try to put it in learn mode all it wants to do is spike to a retarded amount, i was wondering if anyone had a diagram or any suggestions because the avc-r manual gives a crappy illustration and im having difficulty finding any useful info.
Tulsa_S-13
Car: 1991 SR 240sx
These instructions are pretty thorough and should help you out. Setting up the AVCR takes some time just because of the fine tuning necessary to get the most out of it.
Sounds like you have the hoses on the boost actuator backwards. If you find that this persists or that even after you have correctly installed the AVCR that you are limited to 7psi, then you might have a faulty actuator.
idahotuner
Car: 2012 Dodge Ram 2500 6.7 Cummins
93 Nissan Sileighty
93 Honda Civic hatch
2011 Polaris Ranger
i posted a way to adjust all the setting on the avc-r just search avc-r in thread titles posted by me
Tulsa_S-13
Car: 1991 SR 240sx
Hey Adam, it was nice meeting you for the OKC meet.
I'm pretty sure Michael got lost following me once we got into Tulsa
