available horse power from light weight drivetrain
Tdiazsch
Car: 4wheels. a turbo, and a bamf
how much HP is freed up with a light weight flywheel (11) driveshaft(11) and and pulleys w/no AC
just wondering how much is gained and how noticeable the gain and revs are from anyone who has done all three. bc im thinking of doing this instead of beefing up the engine more.
thanks for the input!
SSonic92
Car: 1995 Nissan Altima almost done..
1990 240sx-swap almost ready to go in:)
Doing these three will help out some but it isnt going to be to noticable. What other mods do u have done also? all motors are different so giving you a number would be more of a estimate but would still depend on what else you have done.
Tdiazsch
brian crower 264s camsafts
brian crower titanium retainers
brian crower springs
port/polished
hks rocker arm stoppers
supertech valve stems
supertech valce seals
arp head studs
cometic head gasket
isis intake mani with the s14 throttle pulley
z maf
750 injectors on the way
s15 turbo bout to bolt up
exedy clutch
SS braided cluch line
nismo slace cylinder(damper delete)
front mount with ssq
pretty much standard stuff.
SSonic92
Well with the mods you have now or about to have, you probably will be netting somewhere in the range from 250 to 300hp but like i said thats only a estimate. Every little bit helps so if u feel you want to do it i say go for it. Dyno's will be your friend if your looking for numbers:)
