92zXNY wrote:DTRUONG9 wrote:Also i wrapped the sensor with plumbers tape when i screwed it in..could that break the ground and cause this issue?
Absolutly. Temp sensors are tappered thread, so the more you tighten the sensor, the threads actually "crush" together creating a seal..And a ground. Its possible the thread tape is affecting the circuit. All temp sensors are simply resisrors. When cold they provide a certain resistance, when hot, a higher/lower resistance. The ecu see's these resistances and outputs a signal to whatever the temp sensor (or resistor if you will) conrtols.
Now im a Toyota trained Tecnician by trade, however i prefer nissanss
. On toyota their is generally 3 temp sensors. 1 conrols the gauge in the dash, one contols the fans (when applicable mainly transverse mounted engines) and one transmits a signal to the ecu which controls fuel injector duty/AFR to an extent. And if you go back far enough (obd1) their is a 4th sensor for the cold start injector, but thats irrelevant cause Nisssan didnt use cold start injectors, rarther more fuel in closed loop (Cold start).
So exactly which sesor did you use thread tape on: the single wire or the 2 wire?
Its also possible the sensor itself is faulty. Did you use the NA sensors or the Turbo sensors. So as far as the MPG goes, a faulty temp sensor CAN cause the ecu to never realize the engine is warmed up and stay in closed loop, which intern dumps alot extra fuel in. All you need to test the sensor is DVOM (multimeter). Look up spec for resistance when cold and hot, then test. If its not within spec replace.
