Leaving them empty is fine, it's common for manufacturers to only have one model of radiator for both automatics and manual gearboxes. You might want to put caps over the nipples to keep wasps from deciding it's a good place to nest.Rex wrote:So, the question is what should I do about the old heat exchanger? Will leaving it and the lines (within the rad) empty be an issue, should I fill it with antifreeze, transmission fluid or what?
