aux fuse box
Post all your Nissan electronics, car audio and stereo questions here!
gnarlyskater4000
Car: 06 malibu
i have a bunch of electronics in my car that i need to run, but only once the car is running. below is a pic of the diagram i created and went off of. i thought this was wired correctly, but when i just tried to see if i did i blew the first fuse located between the batt and the relay. any ideas on what i did wrong?? thanks
gnarlyskater4000
Car: 06 malibu
can anyone explain how each number is related to my diagram???im alittle confused on what goes to what....i keep blowin the fuse from the batt to the relay. also what size fuse should i use there??
http://forums.pelicanparts.com...8.jpg
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
Looks like everything is wired up right. Are you just running to the remote wires to turn the amps on? Also, what does the 4th wire go to, and what size fuse ae you running?
gnarlyskater4000
Car: 06 malibu
the converted
Car: '99 BMW M3 6.0
'20 Toyota Tacoma
30 +12v in87 +12v output to components85 and 86 are the trigger and ground.
Your fuse values are going to depend on what you are powering, but most relays won't work for over 30 amps. If all your powering is two amp turn on leads, the 3sixty turn on, and an led I can't see you needing more than 5 amps for a fuse, but what does the 4th wire off your fuse block go to?
gnarlyskater4000
Car: 06 malibu
so ive tried and tried again to get this to work, but i have realized that its not how the relay is wired......i removed the relay from the equation and wired directly to the 12v source and it keeps blowing fuses.....it must be how the led switches and how they are wired.....i cant think of anything else...when i remove all the wiring for that its find....this wiring has me all confused and pissed off at my car
