Torry has a very good map of a possible way of getting there, but it is very specific. at this point, you have plenty of options.
another possible path:
continue doing what you are doing in terms of messing around with cars/getting some hands-on experience.
get into a good state school. it doesnt need to have an automotive engineering program at all. in fact, most 4 year schools dont! (mechanical is what you want, you will specialize in auto classes in your upperclassmen years)
when you are looking over the millions of schools: keep in mind that a BS degree with "technology" pasted on the end of it is less mathematically intensive. Initial salaries vary, but in general a BS in ME will get you more cash off the bat than a BS in an engineering technolgy will. of course, everything is relative, and you should do what you want. salaries become very dependent on your skills, so a tech degree can still get you really really far, if youre that good.
in any case, in general - engineering technology degrees skim over some mathematical details in exchange for a more hands-on approach.
if you dont want to get heavily into the math, a tech degree is exactly what you want.
with a BS from a good state school in ME, these days you could expect anywhere between 30-50k a year, starting. (job market has been bad for engineers, recently) by the time you graduate, it could in fact be much more.
at that point, you could jump into an auto related job, where you would learn everything else you need to know very quickly in your specific field.
if you are really good, some companies will pay for you to get your Masters.
you could also go straight into grad school after you get a BS. (best option in my opinion). in this case, you will be able to do state of the art research in your chosen discipline.
check this link to see what auto research i might soon be choosing from, here:automotive systems:
http://www.mie.uiuc.edu/conten...s.asp
U of I, probably U of Mich also, has a 2 year graduate program: MS in ME, and your MBA. super deal!!
with these degrees, and research, you should be irresistable:easily commanding anywhere in the 40-70k range.
you could get a PhD, but in my opinion, it dooms you to academia: being a prof or researcher. you CAN hold a engineering job, but you will most likely be a manager of sorts. it tends to separate the engineer from the actual work, and these jobs of course are much less available, and tend to pay not more more (starting) than a masters plus the MBA.
FSAE is great...i have been inactive for a while because i have been so busy with my studies.
i went to the status meeting on thursday, and it seems we have a variable intake runner system prototyped....(really cool in my opinion)
in summary, there are lots of paths. if you are smart, a good worker, and dedicated, you should be able to get into doing whatever it is you want to do, by many paths. some might be shorter paths, while others may be less fulfilling. is up to you to make all the decisions along the way.
