streeteg »
https://forums.nicoclub.com/streeteg-u61203.html
Mon Dec 03, 2007 9:35 am
So, I got the car all together and semi running other then some TPS issues which will probably be in another thread... Regardless I need to put the sender somewhere it can be grounded without bootlegging (fitting in a hose thats grounded) So I have to tap somewhere... My queston is... can one of these two be moved? It looks like the red is the stock sender and the other may just be a ground.... but that wouldnt seem right being that there is a ground right next to the two tapped holes.....
Heres a pic for reference...
Oh and if you are wondering why stock guages arent being used its because its in a 74 Z with a custom dash so they done exist....
TIA!-E
