sjbsuperman1425 »
https://forums.nicoclub.com/sjbsuperman1425-u80456.html
Tue Sep 30, 2008 7:32 am
Well i've been searching for awhile now (about a month or two) and have not found a concrete answer. I've searched for both CA18 and SR20 Autometer tach install on different forums and came up with little to nothing. I've read you can use the yellow/red wire from the ECU and it'll work and i've also read that you need to buy a tach adapter and tap into the coil power wires and wire it that way. The only midly concrete answer i got was from a guy from Rhombus-Tuning who used an Autometer Phantom Tach and he said he DID NOT use a tach adapter. But I was hoping someone could give some confirmation or a little walk through of what they did.
BTW, will an Autometer Speedometer wire right up as well? just curious
Thanks Fam.
