Autometer gauge hook up for S13 with Sr20de
uvamosk
I had a person give me a autometer tach. I hooked it up to the battery and then hooked the green wire to the Negative wire off the coil and it would just kinda jump a little when i touched the Green wire to the Negative wire on the coil. It wouldn't actually work.
I just wanted to know if that was the right place to hook it up and also Is there some thing i have to do to set it for the signal. I read somewhere you have to use an adapter or something to convert the 240sx signal to lower voltage.
uvamosk
BUMP does anyone know this...
Wakedrifter
Car: 89 s13 hatch, redtop, greddy vspec, Evo tt exhaust, Kazz, full urathane bushings,
uvamosk
I just need to know where to hook the green wire. I think i had it on the Neg. Coil wire it was Black with red stripe.
uvamosk
Anyone? I am going to try to hook it to the other wire on my coil.
