Nowhere wrote:Uhhh... The innovative unit has a narrow band emulator output.....
humm, what is the scale on the narrowband autometer afr gauge? rich, lean, stoich #'s.
i wouldnt see why you couldnt use the emulated narrowband signal, i did not know the lm-1 had that feature. you could use the emulated narrowband signal and compare the afr gauge to the wideband display, compare the two readings and see if they are the same.
