SuperHatch »
https://forums.nicoclub.com/superhatch-u50790.html
Tue Mar 03, 2009 2:18 am
Even though the Z and Q bellhousings swap, it creates problems. The Z32 bell is a different length than the Q bell, so the trans ends up 1.1" farther back with the Q bell, screwing up clearances, driveshaft, etc.
My suggestion would be a Z TT Auto, which is the same internally as the Q auto, get the Maz adaptor. Use the Z TT flexplate, torque converter, trans, lower harness, and TCU. Then use the Q engine ECU. Adapt the Send/Recieve signals from the Q ECU to the appropriate places on the Z TCU. You may still need a custom driveshaft.
