automatic windows...........
Discussion forum for body kits, repair, modifications, interior styling, Audio / Video and internal/external lighting.
03geethirtyfive
Car: 2003 infinti g35 sedan
All right guys, i know this may sound dumb, but i just got my 03 g35 sedan a week ago and just found out that i can roll down the windows using my remote...(is there a way to get them back u by the way??)..well anyways my question is.... is there anything else cool or neat i should know about my g35 sedan that i probably dont know about??? thx for ur comments and help ahead of time _Mikey_
crna1
Car: 2003 infiniti G35 Coupe
how do you get the windows down with remote?
SVTCOBRA
Car: 2018 Q60 AWD 2023 F150 4x4 5.0 FX4
on my 05's you just hold down the unlock button until they start going down.
on my 05's, to get them up, you can put the key in and turn it and hold and they go up.
zozoka1212
Car: 08 Infiniti G35x
If you want to use your remote to roll the window up. You have to buy a module for it. I beleive kp technology has one for G. It is cheap like $20-30.
zozo
Modified by zozoka1212 at 8:13 PM 11/7/2007
03geethirtyfive
is there anything else i should know thats neat about my G?
joe603
Car: 2014 Durango R/T
...you can set the rev RPM to whatever you want. It's like a shift light.
...The seats will come back to the original position when you push the button on the back. (you have to have the parking brake engaged)
smockers83
Car: 2006 G35 Coupe
You can program the remote to either put them up or down, but not both. There is a switch in the glove compartment that turns on/off the button on the rear of the car for the trunk (both doors have to be unlocked anyway for that button to work). You can program the car to honk/flash lights or just flash lights when you lock it with the remote.
k@osx71
Car: '04 G35 Sedan DP
you can set the rev limit on a '03- '04 sedan? HOW?!?! and how do you program the remote to put the windows up instead of down?
sxtrailrider
Car: sedan G 35
I have the same questions
smockers83
Car: 2006 G35 Coupe
Sorry, I lied I guess. I thought I read it in the manual. You can only set the rev light if you have a manual.
KPierson
Car: 2004 Infiniti TT G35 coupe
You can't get the OEM system to put the windows up - it is not a programmable option. You need aftermarket parts.
The 03s and 04s didn't have REV lights.
99QX4
Car: '07 G35, '05 FX35
joe603 wrote:...you can set the rev RPM to whatever you want. It's like a shift light.
Ahha! That's why mine doesn't go on, because i didn't set it!!
And i only recently discovered that for the memory seats to move the e-brake has to be engaged! (well on my 6spd anyway)
KPierson
KPierson wrote:You can't get the OEM system to put the windows up - it is not a programmable option. You need aftermarket parts.
The part to do this (KPtechnologies NM20 window module) and all other KPtechnologies modules are being offered in a group buy:
zerothread?id=383073
Tampa G35 Sedan 6MT
Car: 2006 Infiniti G35 Sedan 6MT Black w/ Premium & Areo Pkg
1989 Jeep Cherokee 4X4 Lifted and Old School!
I get in and play with all the buttons... I guess I know what everything does
DJ
Return to “G35 and G37 Interior, Exterior and Audio”
