Automatic Windows after Intake Install
BLWNKL 1
Car: 2008 Nissan Altima Coupe
Got my Injen intake installed yesterday. Removed the negative battery cable first per the instructions. Install went great. Now, the automatic windows lower as they did before but they won't automatically raise. Is there something I can do to fix that? I'm sure it's because I disconnected the battery. Is this a simple fix? Anything else I need to be aware of from a re-set perspective (I've taken care of the radio, the dash-information screens and the heater controls)? Thanks.
rjdmmfl1
Car: 2008 Altima Coupe, Radiant Silver, 3.5SE, Premium Package, VDC
this is the point when the veterans usually yell at the newbs because this has been posted at least twice prior to this... however, since people don't like the search function, i'll just make it easier...
roll down the windows slightly more than halfway... then roll then back up and keep pressing the up button for ~ 4 seconds. This will reset this feature!...
oh yeah, its also in the vehicle manual that came with the car... if you take an hour and read through that, it'll also give you some insight on some other useful tidbits of info...
actually, I'll probably do a writeup later today of a couple useful tidbits that will helps folks out when it comes to stuff like that, (window roll up, blinking self restraint sys light, etc)
SHIFT_COUPE
Car: 2014 Infiniti Q50 AWD
I'm not going to yell at you but YES this is in your manual as well
