Post by dhen » https://forums.nicoclub.com/dhen-u100551.html Sun Oct 18, 2009 4:36 am
Post by boost_boy » https://forums.nicoclub.com/boost-boy-u2853.html Sun Oct 18, 2009 6:15 am
It doesn't matter as they aren't really all that different like saaayy the mitsubishi 1G eclipses which use both a 390cc injector and a 450cc injector which means the ecus have different programming. With the CA18DET it doesn't matter as both ecu are tuned for 370cc injectors which means very little different in performance. The transmission ecu is the one that makes them act accordingly (engine runs off ecu and transmission is controlled by transmission tcu).dhen wrote:Just a quick question; I know the tunes are different between automatic and 5-speed, but are the ECUs PHYSICALLY the same? I have a spare automatic ECU that I want to put a 5-speed chip in, and I just wanted to make sure it would work.
Thanks,
Darian
NICOclub's Nissan forums and Infiniti forums and all affiliated sites are the property of HDS Holdings, Inc.
They are independent publications and are not affiliated with or endorsed by Nissan or Infiniti.
Information Copyright © 2000-2026 by NICOclub, all rights reserved. Material may not be copied or reprinted without written permission.
