Megaseth »
https://forums.nicoclub.com/megaseth-u593.html
Mon Nov 22, 2010 8:11 am
It's been a while since I've been on here, but this is the first place I'd go when I have a problem. Here's the lowdown on the situation:
I changed the transmission fluid/filter on the pathfinder this weekend, and now it's giving me some trouble. It had been about 3 years since the last service was done. After changing the fluid on saturday, I figured all was well and things drove fine. But when I went to meet up with my grandparents/parents sunday after a highway drive, my dad noticed a good amount of fluid leaking out. We checked the level and it was way too high. I thought, "great, i overfilled it and now it's dead". But my dad told me it could be the vent tube letting out a lot of the excess. So I drove home slowly, got under the car and checked all the bolts to make sure it was seated. Then, I drained some of the fluid and started the car, went through the gears, got things moving and checked the cold side since it wasn't enough to get the temp up. It was still a bit high, so I drained off a little more and did the same. We drove it around last night to make sure things were ok, and they seemed to be fine. However, this morning, after checking to see if anything was leaking, I checked the fluid level (cold, i know, which is bad) and it was still good. Started the car, drove my girlfriend to school and on the way it shuddered a little, and slipped once, then drove fine the rest of the way, but shuddered a little once again. I checked the fluid there and it was in the safe zone on the hot side. I drove to work without any problems but I'm still worried. I know too much fluid is bad, too little fluid is really bad, shuddering and slippage are bad. Basically, unless it's shifting like butter and revving up smooth, it's bad when it comes to transmission health. So, do I need to start shopping for new transmissions or is my wallet going to live to see christmas?
