onosqv »
https://forums.nicoclub.com/onosqv-u507.html
Tue Apr 08, 2008 11:05 am
Well, I read through your first post again...
Basically, auto ecu has nothing to do w/ your manual swap. You can run either ecu (i.e. in manual cars, you can run either auto or manual ecus... so in your swap, you can run either). Not sure if I can make it any clearer than that, good luck.
If you have questions about sensors and no one is answering to your liking, you can always just refer to the FSM (also downloadable from here if you haven't already), and check the differences yourself.
If you follow the auto->manual guide, you should not have any problems unless you did something really weird...
