Automatic Transmission Pics (Beyond the Pan)
OwnerCS
If you've ever wondered about what lurks behind your automatic transmission pan, here are five pictures below.
Everyone on here stresses the importance of changing transmission fluid. To me this is one of the most important maintenance activities that can save you real money on expensive repairs. When you see what is behind the pan, I think it will bring home the importance of keeping the ATF fresh. Heat is definitely the transmission's enemy..
Personally I like to use an ATF that meets the JASO 1A standard. Though this post is not intended to start an ATF fluid debate, there are top shelf fluids used by members that meet this Japanese quality standard.
Here's a picture with the pan off during my first fluid change. I cleaned the pan magnet, replaced the strainer, o-ring, drain plug crush washer, and installed a new gasket and pan bolts.
Now that I'm certain about the condition of the strainer, o-ring, and gasket, I change fluid using an extractor pump. The extractor pump tube can hit the pan bottom and extract approximately 5 quarts with each change.
Two pictures with the strainer on the transmission below. As you can see from the second picture, the strainer is just that.
These two pictures are intended to show the intricate components and electronics that are submerged in ATF.
paranoidjack
Car: 2012 Infiniti M56 S
2003 Infiniti M45
2001 Infiniti QX4
2000 Infiniti Q45
1998 Nissan Pathfinder
1996 Infiniti J30
I'm not surprised your insides are as clean as your outsides owner! I bet mine is horrific, I just know I'll be replacing it very soon...
OwnerCS
Thanks Jack! I must admit the pictures are from October of last year.. I've been so far behind on doing stuff around here. I'm finally beginning to catch up to where I needed to be on projects in like December.. LOL
