Automatic Transmission Oil Cooler NISSAN PATHFINDER?
jerson3mendo
Car: Nissan Pathfinder 2000 4X4 SE VG33E
hello everyone, I have a concern ..... I have a Nissan Pathfinder SE 4X4, year 2000, it is advisable to install a (Automatic Transmission Oil Cooler, out of the radiator) is used by some vehicles as ......
if anyone has made any recommendation I can do?
greetingsJerson
Densetsu
Car: 2004 Nissan Pathfinder Chinook
Prev: 2003 Nissan Pathfinder Chilkoot
The 96 - 04 Pathys come stock with a transmission cooler; it uses the radiator to cool the fluid. If you check, you should have two small hoses attached to the bottom rear of the radiator, one right beside the lower rad fluid hose and the other on the opposite side.
If you wanted to you could install another transmission cooler, but unless you're towing heavy loads in the mountains I wouldn't worry about it. I've towed a 2000lb boat on high-grade mountain roads with a Pathy that was filled up with camping gear, it never complained.
