automatic transmission oil change
apm285
Car: G35 coupe
Has anyone performed an automatic transmission oil change yet?
I have the nissan j matic oil for the 2003 coupe.
What else is required? do they run filters? Are there any gaskets that need to be replaced?
Also there is an option either to drain the oil from the transmission or feed it through from the radiator hose to fully flush the system until clean oil is visible when disembarking the pipe. What method have you guys used?
Regards
mrsmithGrider
Car: 2003 Infiniti G35 Sedan
There is no filter for our cars...which I thought was wierd. Our transmission are also labeled as non serviceable, which i suppose means that your not reccommeneded to work on them yourself. I have heard too many horror stories about the transmission flush, so I decided to always go with the drain and fill. I had the nissan dealer do it with the j matic fluid for about 45 bucks, of course i bought the fluid online and then brought it in for them to drain and replace. I bought 4 quarts and it didnt take much time for them to do it.
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
Nissan Matic-S is now the replacement for the Matic-J fluid. matic J is fine but the matic S is better.
For a complete flush, it would be best to pull the drain plug and let the car sit overnight. You'll get much more fluid out. Otherwise you'll change out like 6-7 quarts of the 11 that it holds.
I just drain and fill the 6-7 quarts every 20-30K miles and it keeps the transmission fluid looking good.
kmckis1029
Car: 2016 Q50 RS400 AWD
2010 G37x w/Prem, Nav, & Wood (sold)
2005 G35x w/Prem C (traded in)
got the dealer to do a matic S Flush like 2 months ago for my 30k service... i have had no problems and smoother shifting... especially when cold or at low speeds.
pfarmer
Car: 2008 GXS with technology package
kmckis1029 wrote:got the dealer to do a matic S Flush like 2 months ago for my 30k service... i have had no problems and smoother shifting... especially when cold or at low speeds.
For reference, how much? I am thinking of doing a flush at 20k and then a drain and fill every 30k or so after.
Perry
apm285
Car: G35 coupe
Thanks guys im going to do a flush.
Have to buy 12 quarts of oil Thats alright it is always better to do something right from the beginning right? Im very meticulous when it comes to these things.
kmckis1029
uhh i got alot of stuff done that day... ill have to check the work order, im thinking in the $200 range... but i do remember the total was $1200 for :
Royal Purple Oil Change with K&N oil filter
Base Idle check, Timing, and self learn clear
Induction Flush
Front rotors and pads with brake fluid flush (this was the money killer!!!!)
Rotate and balance tires
I got the NEW SYNTHETIC transmission flush (fluid part # BG3124) Both Drive Belts replaced (cracked and a slight squeak)
ZY2503
Hi, My 04 sedan had 68000 miles. I do concern that power flush method could damage the transmission parts, especially on high millege car. Can any one to tell how to refill accurat amount of new fuid, since my car did not have transmission oil dip stick to check. please help.
