IvoryJ30t »
https://forums.nicoclub.com/ivoryj30t-u9485.html
Sat Apr 15, 2006 8:47 am
your radio install had nothing to do with the trans malfunction. unless you cut a wire going to the TCM.
you shouldnt be cutting wires behind the dash anyway, thats what radio harnesses are for.
as far as the trans, the inhibitor switch may be out of adjustment. check the fluid level.what does the fluid look/smell like?
