Postby
SoDelMotorsports »
https://forums.nicoclub.com/sodelmotorsports-u119530.htmlTue Nov 18, 2008 4:08 pm
hey guys hows it going, ive searched all over and cant find the type and capacity of trans fluid that the nissan 240sx A/T takes, any help would be great, thanks in advance. Randy
Postby
onosqv »
https://forums.nicoclub.com/onosqv-u507.htmlTue Nov 18, 2008 10:58 pm
It's in the FSM somewhere. Something like 5-7 quarts 100% capacity (don't quote me on that). If you do a drain and fill, it's usually only like 3 quarts or so.
Postby
SoDelMotorsports »
https://forums.nicoclub.com/sodelmotorsports-u119530.htmlWed Nov 19, 2008 6:09 am
thanks for the help, but i checked at my work on MitchellOnDemand, its saying 7.90 quarts of Dexron II, thats probably with the torque converter also, but im getting a junkyard transmission to put in my car to get it sold, ill just go with the flow and check it after 6 quarts or so... thanks though
Postby
guyaverage »
https://forums.nicoclub.com/guyaverage-u13673.htmlThu Nov 20, 2008 1:48 pm
The 7.9 quart spec includes the pan and converter. The pan itself only holds about 2 of that.
Any Dexron (you wont find II or anything earlier than that, you will find III or VI or whatever) will work. Or a Dexron/Mercon V spec (they are almost the same thing so they get labled that way). Most "multi vehicle" fluids meet the spec.
Car: 1989 240SX Coupe 5sp SOLD 1989 240SX Hatch auto SOLD 1990 240SX Coupe auto WRECKED 1990 240SX Hatch auto 1990 Jetta Turbodiesel 5sp FEILD BAGGED 1997 Jimmy 4WD 1985 Chev Wrangler 1994 F150 4X4
Postby
rsagen »
https://forums.nicoclub.com/rsagen-u135980.htmlMon Feb 15, 2010 9:16 pm
I know this is a old post but im just putting it on the net for future people.
According to a spec sheet, it was 8.3 quarts of ATF including the tourqe converter. and if you dont drain the TC just the fluid thats just dumb cuz your leaving almost 5 quarts of dirty fluid in the transmission to mix with.
