automatic transmission fale safe?
kevinarich
Car: S14
Does my 96 auto have a fail safe mode? Is that why Im getting stuck in 3rd. I also have a cel, its a 123 which is overrun clutch solonoid??? Havent found anything using the SEARCH!!! button. so anyone have any insight? I think aamco is full of poop.
onosqv
Car: '92 240sx Vert
You are absolutely right: stuck in 3rd = fail safe.
This thread may help: 1989 240sx OD problem
ricebike wrote:oh crap!
did you check/replace the trans fluid & engine oil as well???
EXCESSIVE heat will turn that pink fluid to brown... engine oil would be like hersheys syrup... hope you did those things as a follow thru...
-----------------ok, 10 steps for the self-diagnosis of the auto transmission using the OD OFF indicator lamp:
warm up engine/transmission to operating temp
turn key OFF
1: set OD switch ON
2: make sure it's on P ~ key ON, engine not start; do U C OD OFF light on for two seconds? if so, move to step 3
3: key OFF & shift to D
4: set OD switch OFF ~ key ON, engine not start ... wait ~ two seconds
5: shift to 2
6: OD switch ON
7: shift to 1
8: OD switch OFF
9: step on gas pedal all the way & release
10: OD switch ON
then, u should see the OD OFF light flashing 10 times
u r looking for that long flash = the trouble code
if ALL ten flashes da same: OK
1: revolution sensor/circuit shorted or disconnected
2: speed sensor short/disconnected... etc.
3: throttle sensor
4: shift solenoid A
5: shift solenoid B
6: overrun clutch solenoid
7: lock-up solenoid
8: fluid temp sensor disconnected or AT control unit power source is damaged
9: engine revolution signal circuit
10: line pressure solenoid circuit--------------------------XTRA+++
if the OD OFF light is flickering: battery power low, battery disconnected fo long time
if OD OFF light is always on after setting the trans into diagnostic mode: u got a damaged trans control unit or the following is disconnected/shorted:
inhibitor switch, OD switch, kickdown switch, idle switch
hope that helps
Modified by ricebike at 2:51 PM 11/15/2006
kevinarich
Car: S14
Thanks alot that made things easier. I have now concluded that someone before me was doing burnouts in my car and caused the fluid to burn. Causing the failsafe and the overrun to go freak out. I will fix these problems. Thanks you.
