Automatic Transmission Cooler..
izmyttz
Car: 1990 300zx TT-White,
So I'm replacing the radiator and my TT is an automatic and has the transmission cooler built in to the radiator I believe. I was wondering how much harder is the radiator install going to be since I have to buy a new transmission cooler from Z1? can I just unhook the old radiator and pull it out with out any troubles? The small cooler in the front of the car..what is that? An oil cooler? Where would the automatic transmission cooler mount? Geeze this is getting complicated just to replace the radiator.
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
the little cooler up front is for the oil, and you cna use a trans cooler form z1 or summit or whoever, but you'll have to figure out your hose adapting and mounting as you go, anywhere up front where it can get plenty of air is fine, some of the more expensive coolers come with electric fans so you can mount them horizontal and still get plenty of cooling
izmyttz
thanx evil...you kick azz
