The "correct" 1st gear start TCU for your car would come from a 1993 Q45. That's the only year that had a transmission identical to yours in terms of gearing, and came with 1st gear start. It's part number will end with 64U20 or 64U75(rare). You can search for one at
www.car-part.com or check out our classified section here. Many members have had good experiences with the 94-95 TCU as well. Those years were 1st gear start, but had transmissions with different gear ratios. For some reason, I remember that the '96 won't work - but I may be confusing that with the ECU. Either way, they're rare, so it's probably not a problem.
With all of that said, I doubt your problem is a bad TCU. Anyway, the basic run-down of transmissions is that the 90-93 had the same transmission, but the 93 came with a different transmission control unit that started the transmission in 1st instead of 2nd gear. 94-96 had transmissions with slightly different gearing, that started in 1st gear, but should be fairly compatible with your 92. 96 might work, but I'm thinking the transmission controller may not be compatible with your car... Clear as mud, right?
