guyaverage »
https://forums.nicoclub.com/guyaverage-u13673.html
Thu Jan 27, 2005 6:29 am
There were threads about 6-8 months ago that had this type of problem and it ended up being the throttle position sensor.
I was having the opposite problem, my transmission would go into 2nd and third almost right away and not downshift into 2 or 1 when I hit the gas. I ended up replacing the TPS and readjusting the idle to specs. Just out of curiosity I moved the sensor to various extremes and tried it out to see how much affect it really had and I was surprised how much it altered the shift points. Once I set it the way the factory service manual says it really cleaned up the problem.
If you havent checked it already, give it a shot. Also check your speed sensor.
