WDRacing wrote:Should withstand 400 without any problems. I had that much on my Skyline and it has the same transmission. You'll want a good transmission cooler though. Anything from Summit will work well.
WD
i have an auto also that will be boosted in about 2 months, its good to hear a definitive answer from a knoledgeable person about the strength of the auto s13/14 transmission. for some strange reason i had the weird number of 240whp before the converter starts to get unhappy.
WD is the stall on the auto skyline converter set @ 1800 as the s14 auto? you power braked it to build boost with that low of a stall to launch from the line or neutral drop at the track.
how much power was your skyline making and how were the shifts, progressivly getting softer as the bands get weaker, signifigantly? or the wear would be expected with the amount of power, not prematurly.
NA auto s14, on a good day ill chirp second in d shifting, just wondering if it will still have that hard good crisp shifting charictoristics.
