Automatic trans question?
240sx2soon
Car: Soon to be 96 240SX SE
I know years back when I owned a mustang that there were several companies that made shift improvment kits for automatic equipped stangs. Do they make similar kits for the KA auto tanny? I also need to have my transmission fluid changed, any suggestions on a type of replacement fluid for it or are they all pretty much the same? Thanks
whiteonwhite240sx
Car: 96 240sx
I also would like a shift improvement kit! Firmer quicker shifting automatics get less heat because of less slippage & will last longer! I plan on geting an aftermarket trany cooler n some good ATF! when my setup takes a dump on me ial do a swap,donno which 1 yet but it will b a manuel 4 sho!!!
SOME1 FIND US A AUTO SHIFT IMPROVEMENT KIT!!! MINES A 96 240SX W/ AUTOMATIC 4 NOW!
benemorius
Car: s13, s13, eg, e36
There is a pressure dropping resistor under the hood mounted to the driver side shock tower that you can disconnect for quicker, more agressive shifts. It won't move your shift points, but I don't think the stock shift points are really that bad on a 240 anyway.
