Importroller »
https://forums.nicoclub.com/importroller-u2417.html
Tue Mar 30, 2004 6:19 pm
I think my Torque Converter is going bad. Lately, I've been having problems getting the car to roll once it goes into low gear from a dead stop or low speed acceleration. I did a stall speed test, and the RPMS went up over 1000rpms more than its suppose to do stock. SO now, I have to replace the TC
i just went in the garage and toyed around a bit to see if the TC was acting up.
at first, I would put it in gear, and I would need to push on the gas for the car to start moving. So I jacked it up, got the wheels off the ground and did the same thing. wheels only moved when I gave it gas. Its suppose to move automatically if its in gear and no brake is being applied. So I get under the car, to see if I had access to the TC bolts access panel, and the center cross member has it blocked. So, I cant get to it. but while I was under there (car still in gear) suddenly, the wheel (dr side) starts turning on its own. So now, I think it maybe a Valve body body or TCU (transmission Computer Unit) problem. I ran a self diag on the trans computer, and it came up normal..No problems. But there is a problem. So then I did anothe stall speed test. this time, it went up about 400rpms higher than normal, but quickly dropped back to the normal 2300rpms. So now, I dont think its the Torque Converter, but it maybe somethine electronic. But I know the TC isnt and electrical component, its a mechanical one. So even if there was a problem elsewhere, the stall speed shouldnt change. Im getting a VB upgrade in the next 2 or 3 weeks, and I think im gonna get a transmission flush this friday to see if that helps
