Automatic trans button on floor by gas pedal
sleepersilvia92
Car: 1993 240sx coupe s1 rb25det,1989 hatch sr20det
what is the button on the floor under the gas pedal that clicks when u floor the pedal
The Inflicted
Car: 1995 Nissan S14.5, 1992 Nissan 240SX Convertible
I believe it's called the kickdown switch. It's what tells the transmission to downshift a gear for passing, or more accurately, it slightly raises all the shifting points for the gears, which means you shift later and get closer to the redline on each gear.
sleepersilvia92
ok thanks alot
elo240
I believe it is an AC cut out switch. If you have the AC on and are a wide open throttle it will turn off the compressor to give you more power. The transmission is controlled by the TPS.
Hijacker
Car: '92 240sx Convertible
'94 F-150
The switch on the floor is called the kickdown switch. It's another switch to tell the ATCU that the pedal is pressed to the floor. There's also the Throttle Position Switch that's integrated into the TPS that tells the ATCU whether the car is at Idle or full throttle.
Also, the kickdown switch is an A/T only switch. It has no bearing on the AC system and only reports that the gas pedal is completely depressed to the ATCU
S13xCrazy
Car: 1993 240sx Vert, 1993 BMW 325i, 1993 Honda CBR F2, 1998 Infiniti Q45,
^^This kickdown switch...Think maybe it has something to do with our shifting problems in the automatics? Think maybe it is stuck on or something???
Hijacker
'94 F-150
It's possible. It could just be out of adjustment. The service manual has a whole section devoted to the sensors and switches for the AT not shifting properly.
I honestly don't deal with ATs on these cars. I've driven one 240SX with an AT, and that got promptly ripped out for a 5 speed (and an SR)
S13xCrazy
Hijacker wrote:It's possible. It could just be out of adjustment. The service manual has a whole section devoted to the sensors and switches for the AT not shifting properly.
Hmmm...interesting, it was just a thought
Service manual the same as owners manual?
Hijacker
'94 F-150
Much much different. The service manual has everything about working on the car mechanically/electrically. The owners manual just tells you to leave your seatbelts clicked in place and squirm out from under them when you open your door.
